Use the following commands to configure a CFM segment.
Some of these commands are optional and, if not configured, the default values are used. Default Values for Delay Measurement for a CFM Segment lists the default values for delay measurement for a CFM segment.
| Configuration | Default Values |
| Transmit interval | 10 seconds |
| Window | 60 frames |
| Timeout | 50 milliseconds |
| Alarm threshold | 10% |
| Clear threshold | 95% |
| Dot1p priority | 6 |
Default Values for Loss Measurement for a CFM Segment lists the default values for loss measurement for a CFM segment.
| LMM Transmit interval | 90 seconds |
| Window | 1200 frames |
| SES threshold | 0.01 |
| Consecutive available count | 4 |
The statistics for a particular transmission are preserved until the user triggers the transmission once again or if clear counters cfm segment is triggered from the CLI.
